2002 Ford Windstar - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 04:22 PM
KENMO's Avatar
St Louis Blues fan....
2002 Ford Windstar
Asking for my Dad, so please be kind...
My Dad has a 2002 Ford Windstar with a 3.8L V6. Can anyone kindly let me know where the OSS sensor is located? He's getting a P0720 OBD2 code and it is indicating the OSS sensor needs replacing. He has previously replaced the TSS sensor and that was too easy to find...
Thanks kindly...
Ken
Old 09-11-2011, 09:27 PM
willowbilly3's Avatar
Last journal entry: Body mods
Just because it flashes a code doesn't necessarily mean you are supposed to throw that part at it. It is just giving you a general area to diagnose.
Old 09-12-2011, 07:29 AM
tnsmith10's Avatar
when will it rain???
Thanks kindly...
Ken
the OSS is found on the main part of the case down about 1/2 way. its directly under the exhaust manifold on the firewall side.
even though i have seen those sensors fail but, with the explanation that the ISS (turbine sensor) has already been replaced already could lead to something else wrong. it could be a ground or pcm issue, a problem with the wiring harness or, it could be internal.
the best thing to do is remove the sensor and check with a DVOM, or take the vehicle to a transmission shop and have them drive it with a scan tool hooked up in data stream mode to verify OSS operation (or the lack there of).
1995 Ford Windstar Front Subframe awbazar Suspension - Brakes - Steering 8 12-20-2010 04:38 AM
Ford Windstar rear door light... awbazar Electrical 4 12-06-2008 11:29 AM
Ford Windstar engine interchange jvanbu5132 Engine 4 10-05-2008 08:16 AM
2002 Ford Explorer. Skunk Engine 1 09-05-2005 08:49 PM
Help!! Ford Windstar Transmission Problems NAIRB Transmission - Rearend 0 05-11-2004 08:25 PM
