#1
2002 gmc sonoma dont charge
my sonoma woont hold a charge i have already had alternator tested was told its as good as any they would give me off their shelf we checked all connections every wire to
Register now (free) or login to remove ads |
#2
Moving to electrical forum.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne Midnight Sun Street Rod Association |
#3
More likly than not if the alternator is charging properly, the battery is going away. the battery test is to pull a heavy discharge then measure the specific gravity of the electrolyte and how long it takes to recover a charge. The risk is that if the battery is internally shorting cell to cell it could develop enough of a ground path that the alternator commits suicide trying to match the discharge rate (it will rise to the occasion till it burns out). The sooner you fix this the less likely you'll be buying an alternator and battery. The other condition of a continuously discharging battery can be a back flow of voltage through the alternator's diodes. Normal checks at the parts store will not reveal this condition. One way to check is with the engine off, and all other electrical systems off, disconnect the alternator wire where it connects to the battery, with a VOM connect the ground side to the alternator wire and the positive side to the battery's positive terminal, if a voltage is present, one, two or all 3 diodes are leaking backwards current. Keep in mind that these computer intensive modern vehicles are always using low levels of power to maintain memories, keep security systems running, keep the radio from loosing it's preset stations, etc. As the battery ages it looses it's ability to keep all this up even though the drain is small. Bogie |
#4
Did you have the battery tested while you were there ? Cole
| Thread Tools | Search this Thread |
| Similar Threads for: "2002 gmc sonoma dont charge" | ||||
| Sonoma A/C Help | onvol | General Rodding Tech | 1 | 08-09-2009 03:35 PM |
| 94 gmc sonoma prob. | 1972bigblockchev | Engine | 2 | 03-06-2008 05:26 PM |
| Super charge/Turbo charge | Meka | Engine | 8 | 11-24-2003 06:33 PM |
| 2.8L in a 1993 GMC Sonoma | Shama Jacob | Engine | 4 | 09-24-2003 12:03 PM |
| Turbo charge or super charge for a small block olds | Andrew7dg | Engine | 2 | 11-12-2002 11:23 AM |
