2002 Grand Prix RPM flucuation - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2008, 05:29 PM
hey guys,
my daily driver is a 2002 Grand Prix. the car has 125,000 miles on it. a couple of weeks ago, i started having problems where the rpms would start to flucuate between 1700 and 2200 while i was driving. this only happens for a few seconds after the car is in 4 gear and i am doing around 45-55 mph. then it will run normally, but it will do it again if i slow down a little bit and try to accelerate again. i did a tune up, changed the fuel filter, changed the trans filter and fluid all at 100,000 miles.
i plugged it into my handheld scanner, but it didn't show any faults. i took the car to the trans shop today and they said the trans is fine, it has to be something with the engine.
any ideas ???
thanks in advance for any info you can provide.
Old 10-11-2008, 05:33 PM
any ideas ???
Because you think this is a engine related issue ... as Moderator I am going to move this thread to the engine area
Deuce ... Moderator
Old 10-11-2008, 08:06 PM
Wiki Edits: 31
take it to a shop that has a good scanner.. drive the car around with them, and have them plug in the scanner, a problem like this has to be a sensor of some sort.. TPS most likely but it almost cant be... could be a failsafe but your CEL would be on then, and you would have a code..
Old 10-12-2008, 11:52 AM
T-bucket23's Avatar
Wiki Edits: 26
hey guys,
any ideas ???
Sounds like the transmission is not staying in OD righ away
Chet
Old 10-12-2008, 02:58 PM
yeah, i thought it was something to do with the overdrive also, that's why i took it to the trans shop this weekend. they insist that there is nothing wrong with the trans. it is puzzling why the check engine light hasn't come on or why it doesn't show any codes when i use the scanner.
Old 10-12-2008, 03:33 PM
hey guys,
any ideas ???
Check B+ line voltage, if the alternator isn't keeping operating voltage up, the computer will cause the tranny to hunt in and out of converter lock up as well as in and out of overdrive.
On the engine this can be an IAC problem where the idle control motor is hunting for it's proper opening, this is usually the result of a poor or missing road speed sensor input to the computer, this can also be a sign of low B+ voltage. This usually will not set a code. The IAC usually shows as hunting in cruise, or dropped idle speed and stalling when coming to a halt, or as a hesitation when the throttle is opened after coasting down in gear some X amount of mph, then re-accelerating to cruise speed again.
Bogie
just passed the 1000 dead mark bullheimer Off-Topic 54 05-03-2009 09:31 PM
single vs. dual plane- which should i use? WsXs3 Engine 9 02-25-2006 07:35 AM
New RPM Dual Quad Air-Gap Intake bccsrc Engine 7 01-31-2006 04:29 PM
vortec heads on sbc 400 camino_man Engine 16 11-11-2005 01:33 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
