2002 Kia Spectra Window Help Please! :) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2012, 06:45 PM
chevyrestore's Avatar
Hey everyone, my neighbor has a 2002 kia spectra with a weird window problem and it has my head spinning.
Heres what happens
RF, RR, LR windows all work properly on their own switch but only go up with the master switch, fuse does not blow bringing these windows down
LF window goes down properly but blows Left side window fuse when trying to go up.
I uploaded a pic online and put the link below of the schematic for help. Thanks everyone
http://www.flickr.com/photos/7456878...0427/lightbox/
Old 01-24-2012, 07:08 PM
T-bucket23's Avatar
Wiki Edits: 26
Broken wires in the rubber boot between the body and door. Common issue
Chet
Old 01-25-2012, 10:53 PM
wires all look good on that boot going from the door to the body, any other recommendations based on that schematic?
Old 01-26-2012, 06:33 AM
T-bucket23's Avatar
Wiki Edits: 26
Maybe the master switch itself is shorted internally
Chet
Old 01-26-2012, 09:52 AM
I noticed when trying to make the other windows go down with the master switch they make a tap noise like its getting the signal but they dont move.
Old 01-26-2012, 09:13 PM
LATECH's Avatar
Heres what happens
Could be a short in the Blue with Yellow wire ( Marked as L/Y ) from the drivers switch pin 12 to drivers side motor pin one.
That would allow the drivers window to go down but short the fuse when the otherside of the switch powers the circuit to go up.
The other 3 windows only raising from the master implicates a circuit board problem in the master switch. After pouring over the schematic , it is the only thing that makes sense.
The entire problem could be the switch, but before replacing it, I would check the Blue /yellow ( Marked L/Y) for a short to ground so you dont damage the new switch as it sounds like there could be two seperate problems with the car.
I see the auto function in the switch , but it wouldnt cause a problem as such , being it is in a parallel circuit with the switches and is designed to mechanically hold the drivers switch to run the window down,it neither powers or grounds the window circuit, if it was bad it would be a direct and immediate short or a complete open.
Old 02-10-2012, 11:22 PM
Hey thanks everyone just wanted to let you know what fixed it, ordered a new switch, hope that will fix the right side problems, as far as the blowing fuse I replaced the motor and that fixed it. I figured it was drawing too much amperage and apparently it was
front brake installation 4 a 2005 kia spectra wiser626 Suspension - Brakes - Steering 2 12-16-2010 06:23 PM
1937 dodge coupe 3 window or 5 window jackie bowman General Rodding Tech 6 07-28-2010 08:24 AM
32 Ford 3 window window mechanics Tansmith Hotrodding Basics 2 10-24-2009 08:37 AM
Window channels and removing vent window Jackyl Interior 11 10-10-2007 07:01 AM
Interior window trim (frames) for 34 5 window Ford Ken@Ft. Lauderdale Hotrodders' Lounge 1 03-10-2002 05:16 PM
