2002 mercury cougar tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2007, 02:30 PM
the transmission revs to about 3 grand before it goes into gear then works fine I was wondering if any one has any ideas on what could be wrong could it be the tcc But wouldn,t that throw a code.
Old 05-09-2007, 02:42 PM
Transmission woes
I have a 2002 Explorer. At 124,000 miles the same thing happened to me. Two week later my transmission was toast. How many miles are on the car?
Old 05-09-2007, 03:10 PM
its got about 110,000 on it
Old 05-09-2007, 03:11 PM
just wondering because it works fine after 1st it is just that first start up going into first of course the warranty just went out
Old 05-09-2007, 08:50 PM
Crosley's Avatar
Wiki Edits: 1659
is the trans full of fluid? serviced lately or ever?
big pressure leak or worn out pump. rev the engine up to get fluid traveling fast enough the trans jumps into gear.
sometimes a quart of 10w-30 motor oil will help get the trans in gear easier.
Old 05-10-2007, 06:40 AM
2002 mecury cougar
The prognosis is not good for this trans. It may even be low on fluid, and that may have been your only problem.
But if it has been low on fluid for long enough, this transmission is probably hurt.
Old 05-10-2007, 09:15 AM
Tranny
My Explorer showed a code which the dealership reset and than tested the tranny solenoids. They said it was fine and to drive it. The code and the problem came back the next day. One week later, poof. Not a cheap fix either.
Old 05-11-2007, 01:42 PM
I'm sorry it is just over 60,000 on it and the fluid is at the right level there are no codes I notice that the o/d light displays from time to time I'm leaning to maybe a possible short in one of the sensors maybe any info or something I am over looking wood be of great help thanks.
Old 05-12-2007, 02:51 PM
2002 mercury cougar
BIGMIKE, sorry, but reread post # 5. I think Crosley nailed it.
Old 05-12-2007, 04:40 PM
Crosley's Avatar
Wiki Edits: 1659
sensors / solenoids do not put the trans into gear.... it is hydraulic pressure. The shifter moves a valve that directs oil flow for initial engagement.
Now IF a sensor or solenoid is broken , blowing off fluid, e.g. = big leak , this would cause a "no" engagement at engine idle rpm.
If there is a short in a solenoid / sensor.... you have hard DTC pop up..... DTC being trouble codes
63 tranny problems 1badcamero Transmission - Rearend 1 04-13-2003 06:55 AM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
tranny problems joes350truck1 Engine 6 12-15-2002 08:44 PM
64 Falcon tranny swap problems Halteclere Transmission - Rearend 5 12-15-2002 12:46 PM
Carb vacum for tranny problems. kemo Engine 2 11-20-2002 06:15 PM
