Thread Tools Search this Thread share on Facebook
  #1
Old 02-12-2009, 06:52 PM
SonnyFaust's Avatar
SonnyFaust SonnyFaust is offline
2002 neon engine to a 98 breeze?
i have a 1998 plymouth breeze with a 2.0 SOHC engine. I have installed a 2002 engine out of a dodge neon (same type engine)2.0 SOHC with 30k miles on it. The crankshaft position sensors are located in different places and the 2002 engine does not have an EGR valve the other engine did. I extended the wires for the cranksensor. Everything seems to be hooked up and done correctly. I had to use the intake manifold off the old engine and make a plate to cover the side of the intake where the EGR valve connected. The engine will not start. It is getting fire it seems to me like the timing is off or something. Im not sure if the two engines are compatible. but everything mounts up. It just seems like something small. Is it possible that the engine needs the computer out of a 2002model rather than the 1998 or what? If anyone can help me out, or refer me to someone or a website it would be greatly appriciated!!
Register now (free) or login to remove ads
Old 02-13-2009, 08:48 AM
Scotto Scotto is offline
They do require a computer from the 2002, the 98 runs a different computer. I'm not too familiar with the other parts of this swap. But check out Neons.org, I have read about using the new motors o older models there before.
Old 02-13-2009, 01:24 PM
SonnyFaust's Avatar
well i appriciate the help if you or any one else can think of anything else let me know.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "2002 neon engine to a 98 breeze?"
ThreadThread StarterForumRepliesLast Post
the history of chevy v8'ssavman1Hotrodders' Lounge4303-02-2012 06:57 PM
crate chevy 302???Vancouver Grand PrixEngine9205-07-2010 06:25 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no)Malibu73Hotrodders' Lounge3911-04-2008 12:37 PM
new engine build in a 98 yukon?rreruptionEngine212-24-2007 09:48 AM
98 dodge neon fuel problemcrabtreejnmIntroduce Yourself209-17-2005 07:27 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
