Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 S-10 transmission problems
Old 08-16-2012, 07:12 AM
shee4202 shee4202 is offline
I took it all apart to check the connections and noticed a couple of the wire threads at the connection we're cut I'm not sure if this would make any difference but I went and bought a new ignition switch and im going to try it again without them quick connections I'm going to solder the wires for the remote start on instead of using quick connectors this is also going to tell me if it was a ignition switch or not so it will be a nice connection all the way through if the problem persists I'm going to unplug the remote start and run it for a day I cant see it be anything wrong with the transmission I parked it for over year and before I parked it everyrhing ran fine I just started driving it recently and I notice a problem
