2002 Silverado Distributor problem (rubbing?) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2010, 01:53 PM
327amc's Avatar
Owner of a broken cart
I have a 2002 Silverado with 4.3. Im now replacing my 3rd cap.
Once i installed the new cap and rotor, i was able to start the truck. That fixed my previous problem. But now it sounds like something inside the cap is rubbing slightly off center (a tapping sound). If you put your hand on the cap while running, you can feel it. And additionally if you put a slight amount of pressure on the front of the cap and push backwards (towards firewall), the sound diminishes.
We removed the cap and rotor and checked them out, and reinstalled them. Making sure all was aligned. Same result. A rubbing/tapping sound.
With the cap and rotor off, i can grab the rotor mounting plate and seem to be able to wobble it a bit. Maybe 3-4mm's. But seems only in one direction (towards fire wall).
Anyone seen these distri's have bushings in them that go bad?
Am i way off base?
Do we need a big hammer?
Thanks in advance!
Old 02-28-2010, 02:45 AM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
i've some of those distributors last a very long time, others that needed to be replaced before 50K because of excessive wear like you have.
i've never had one apart, but i don't believe there is a bushing in the top of it.
Old 02-28-2010, 09:36 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
There is a bushing, but it's not really serviceable. Replacement time....
Old 01-23-2011, 10:12 PM
Same problem here
What did you end up haveing to do? I have the same problem replaced the cap and rotor and same clicking/rubbing noise and can feel it when you touch it. What all did you have to do to correct the problem.
Thank you,
Jeff
Old 01-23-2011, 11:27 PM
327amc's Avatar
Ordered a new dist. Have not put it in yet. Plan to when the weather breaks...... or the truck breaks. Till then, its still goin.... some how.
Get with Pat on a new dist. He's a great feller, and great parts.
http://shop.ebay.com/patriotperforma...&_trksid=p3686
Old 01-24-2011, 07:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I bought a 1/2 ton PU from the local electric co-op for a couple hundred dollars awhile ago- had a blown engine, 4.3L V6 like yours.
Upon disassembly, I found the crank in two pieces. Also found the distributor's top bushing worn out real bad. The distributor may have been a cause of the crank failure, due to spark scatter lighting off cylinders that were in opposition to one another. Those cranks have the "slipped disc" arrangement and are none to beefy where the rod journal offsets occur.
Bottom line is I would replace it ASAP, just to be on the safe side. I'm guessing you already know, but turn the engine to TDC on the damper and tab. The rotor will be pointing at either #1 or #4. Reinstall the same way, this just makes it easier to keep your place w/the installation. Once the distributor is out, don't turn the engine over.
Old 01-25-2011, 11:37 AM
It give me a P0171 code on the computer also saying bank 1 is running lean could be the O2 sensor also, maybe the O2 bad causing the distributer to misfire ???? It run fine during acceleration and cruising just at idle rpms drop and wants to die. Thanks for the info good luck!
Old 01-25-2011, 11:43 AM
327amc's Avatar
Can the dist be pulled without moving the motor? (clearence)
LATECH's Avatar
sounds more like an air leak/unmetered air getting in the system. Could be injector seals, or a pcv issue or other
Old 01-25-2011, 12:12 PM
LATECH's Avatar
sounds like an air leak
Old 03-27-2013, 12:01 AM
327amc's Avatar
We replaced the stock distributor with a 'stock replacement' ordered online (I dont know where he ordered it from). And the truck fired right up, but had a slight vibration/miss to it.
Took it to the mechanic, he said the 'stock replacement' dist's arent exactly right alot of times. He put in an OEM dist and all is solved.
just passed the 1000 dead mark bullheimer Off-Topic 54 05-03-2009 10:31 PM
Ford dealer tells it like it is. anthonyc1 Hotrodders' Lounge 56 12-25-2008 12:47 PM
2001 ram & 2002 ram front end DavidCarr87m Body - Exterior 0 02-11-2006 06:39 PM
Tire rubbing on bedside guba_unus Transmission - Rearend 4 01-02-2006 05:16 PM
Belmont Shore 2002 Car Show photos xl1ken Hotrodders' Lounge 0 09-13-2002 11:46 PM
