2002 tahoe, fault cod p1860 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 11:19 PM
After changing the Trans filter and fluid, I get a fault code p1860 : Torque converter clutch pulse with modulator solenoid circuit. Could it be possible I damage one of circuits while trying to remove the oil pan?
Old 11-09-2010, 05:39 AM
tnsmith10's Avatar
when will it rain???
the pwm tcc solenoid is in the valve body next to the lockup solenoid. its possible that it got unhooked or damaged changing the filter.
Old 11-09-2010, 04:33 PM
You got it
You are correct sir, plug off one of the solenoids, Thanks.
