2002 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2012, 06:57 AM
2002 vortec
ok got a question about this engine i bought for my 51 1/2 ton truck . i dont know crap about engine building so i need advice on tis engin 2002 L31 vortec . the guy i bought it from rebuilt it converted to carb which will be 800cfm rochester quad and put this cam it with no mods. will i have problems running this cam such as vac. lift, springs, mpg. if so can someone recomend a cam for me. like i said im not an egine builder. this will be a daily driver. all advice welcome. just want something with good streetability with a little gitty up.
valve lift int. .480 exh. .480
cam lift .320 exh. .320
duration [sae] 287 287 valve lash hyd.
centrline 107 111 spread 109
timing events@ .050 cam lift
opens btc 8 bbc46
closes abc 42 atc4
duration int 230 exh 230
rocker ratio 1.5
Thanks
John
Old 11-23-2012, 08:02 AM
2002 vortec
this is a 5.7.
John
Old 11-24-2012, 10:32 AM
opens btc 8 bbc46
closes abc 42 atc4
rocker ratio 1.5
Thanks
John
seems close to the 4X4 cam comp offers. Thats alot of duration I think you will need to follow comps advice for the
08-414-8 Xtreme 4x4.
Hydraulic Roller-Strong mid-range power, needs headers, 3.73-4.10 gears, 2500 stall, rough idle.
less duration with around the same lift I would think.
But i'm on my first build as we speak so take my advice for what it's worth
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
im converting a 96 350 vortec and putting in a 99 454 vortec rkoontz93 Introduce Yourself 1 05-11-2010 04:26 PM
2002 impala mrgoodwrench Introduce Yourself 1 03-11-2008 08:14 PM
2002 5.3 into 82 EL CAMINO sleepyp1 Engine 1 12-30-2004 09:55 AM
2002 MUSTANG GT neil madsen Hotrodders' Lounge 2 12-02-2002 01:34 PM
