2002 z28 camaro rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 04:57 PM
I have a 2002 Z28 Camaro Automatic. I want to put the 3.73 gear ratio in it. But what is the ratio that comes stock,i can do 70mph in overdrive at 2000 rpm. Also what are the best mid tube headers that is a direct bolt on with all the smog hook ups. I'm looking at the pacesetter headers maybe.
Old 05-10-2007, 10:07 PM
my guess 3:27 gears
verify this by counting pinion teeth and ring teeth then divide the ring by the pinion teeth
example 41 ring gear divided by 10 pinion gear teeth=4.11
Question on 67-69 Z28 Camaro.... Mad_Max Engine 4 10-01-2006 04:51 PM
1978 z28 camaro rod69 Engine 5 09-29-2006 06:51 AM
Are 67-69 Z28 Camaro stripes the same pattern? shockers69 Body - Exterior 2 04-09-2005 08:47 PM
85 camaro z28 tpi B-Body-MAN Engine 9 01-03-2005 12:22 AM
2002 camaro flipped 2002needsfixin Body - Exterior 9 03-24-2003 06:26 AM
