have you tried flushing the radiator buildup can cause an engine to run hot are you loosing any water or is it always full something people always over look is the radiator cap the springs can become weak they will open way to soon you will loose water causing it to run hot.... also id recommend replacing the temperature sensor n body chevy Malibu were pron to having faulty temp sensors causing false readings.. i know its not a malibu but a lot of sensors interchange
