Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 zr2 overheating problems.
Old 08-17-2010, 04:37 PM
SonnyFaust's Avatar
SonnyFaust SonnyFaust is offline
i did check the cap it looked good to me. i was also thinking maybe it was just the temp sensor as well but i popped the hood and it was hooootttt. so i figured that it was correct. i did however decide to take your advice on the radiator. It wasnt leaking all the fluid was clean. i had already flushed the system when i put the waterpump on. As it turns out the radiator was apparently bad because i decided just to put a new one in it and its doing good now thanks for the help. i didnt know radiators could go bad unless they busted. i thot they just get dirty. idk im fairly inexpirienced. but thanks and have a blessed day.
