Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2002 zr2 overheating problems.
Old 08-18-2010, 11:22 PM
rtyauch301 rtyauch301 is offline
Originally Posted by SonnyFaust
i did check the cap it looked good to me. i was also thinking maybe it was just the temp sensor as well but i popped the hood and it was hooootttt. so i figured that it was correct. i did however decide to take your advice on the radiator. It wasnt leaking all the fluid was clean. i had already flushed the system when i put the waterpump on. As it turns out the radiator was apparently bad because i decided just to put a new one in it and its doing good now thanks for the help. i didnt know radiators could go bad unless they busted. i thot they just get dirty. idk im fairly inexpirienced. but thanks and have a blessed day.
it wasnt really bad a proper radiator shop could have removed the tanks and cleaned it and you would have been ready to roll so for back up purposes id hang on to that old one
