Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2003 4l60e swapped out for a 2002 model?
Old 11-10-2012, 05:11 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
in 2003 , GM changed the mhz rating and connector on the PCS on the valve body.
I have swapped in older design (pre 2003) into newer vehicles and had no problems or codes set.
I would think swap in the newer version into older design application vehicle , would be fine too. Have veriifed that
