2003 4l60e swapped out for a 2002 model?
i have a 2003 gmc sierra z71 with a 4l60e. i lost 3rd gear. i was told i had to change it out with another 2003 tranny because off changes in the electronics. they have 2 2002 trannys available but said they could not be swapped out with a 2003 model. anyone no if theres anyway i can use the 02 model. how much of a difference would electronic changes make? the trannys looked exactly the same
what want a 2002 4L60e swap out with a 2003 model
why want a 2002 4L60e swap out with a 2003 model. its in a sierra z71. the 2 trannys look the same on he outside
Please do not start multiple threads on same subject. Simply post in the original thread to bring it back to the top
in 2003 , GM changed the mhz rating and connector on the PCS on the valve body.
I have swapped in older design (pre 2003) into newer vehicles and had no problems or codes set. I would think swap in the newer version into older design application vehicle , would be fine too. Have veriifed that |
could i simply put my 2003 valve body in place of the valve body in the 2002 tranny?
| All times are GMT -6. The time now is 06:02 AM. |
