2003 4l60e swapped out for a 2002 model? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 07:43 PM
i have a 2003 gmc sierra z71 with a 4l60e. i lost 3rd gear. i was told i had to change it out with another 2003 tranny because off changes in the electronics. they have 2 2002 trannys available but said they could not be swapped out with a 2003 model. anyone no if theres anyway i can use the 02 model. how much of a difference would electronic changes make? the trannys looked exactly the same
Old 11-10-2012, 07:52 AM
what want a 2002 4L60e swap out with a 2003 model
why want a 2002 4L60e swap out with a 2003 model. its in a sierra z71. the 2 trannys look the same on he outside
Old 11-10-2012, 04:55 PM
Crosley's Avatar
Wiki Edits: 1659
Please do not start multiple threads on same subject. Simply post in the original thread to bring it back to the top
Old 11-10-2012, 05:11 PM
Crosley's Avatar
Wiki Edits: 1659
in 2003 , GM changed the mhz rating and connector on the PCS on the valve body.
I have swapped in older design (pre 2003) into newer vehicles and had no problems or codes set.
I would think swap in the newer version into older design application vehicle , would be fine too. Have veriifed that
Old 11-21-2012, 04:12 PM
could i simply put my 2003 valve body in place of the valve body in the 2002 tranny?
700R4 to 4L60E swapped already chevyconfederate Transmission - Rearend 5 03-22-2012 03:12 PM
Stumped on 4L60E 2003 forward in neutral after rebuild BlkSkyCo Transmission - Rearend 14 01-04-2012 08:48 AM
2002 4L60E rebuild with some issues...... Sierra02 Transmission - Rearend 8 12-21-2011 02:39 PM
swapped engine, now 4l60e trans wont work. heavyfooted Transmission - Rearend 0 05-22-2010 05:32 PM
2002 blazer 4l60e problems lp14255 Transmission - Rearend 11 12-27-2008 12:26 PM
