2003 4l80e has no reverse foreward gears and 4x4 still work perfect. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 06:31 AM
I have a 2003 gmc 2500hd and I think it has a 4l80e trans. I pulled a heavy load home had to put it in four wheel drive to park it in the field when I put it in reverse to back it up I had no response. No sound, no rpm change nothing. And all foreword gears pull strong. What do u think it could be?
Old 01-15-2012, 09:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if the forward 4 gears work ''perfect'' , then the problem with reverse is the rear band. Burned up band, broken servo piston are a couple of possible problems
4l80E, no reverse when hot? rage123 Transmission - Rearend 0 09-14-2010 08:19 AM
4l80e no 4 gear and no reverse Brother777 Transmission - Rearend 2 07-03-2010 09:58 AM
4L80E No 4th and No Reverse 123pugsy Transmission - Rearend 22 12-17-2009 07:46 PM
perfect gears Geiger Transmission - Rearend 7 08-04-2007 09:20 PM
4l80e no reverse tnsmith10 Transmission - Rearend 3 04-06-2006 09:07 PM
