Will that also throw the speedo off and will I have to flash the computer I am thinking yes. Also the GU6 would be the 3:42 correct and the GU5 would be the 3:73? Is the 3:42 a better option as far a maybe upping the mileage 2-3 mpg?
GU5 is a 3.23, GU6 is 3.42 and GT4 is 3.73. Changing from 4.10 to 3.73 isn't going to be much of a change. The 3.42 is very popular and works pretty well in most cases. Don't plan on towing anything or hauling much with the 3.42. I doubt that the 2.2 is going to have enough torque to pull a load like that.
Calculators Play with this and try some tire sizes and gear ratios and see what you come up with. |
Thanks a million Buddy I really appreciate all your input
You won't be happy with 3.42 gears. With your little motor you'll be running in 4th or third and rarely in overdrive 5th.
What type of country you live in? Flat roads no hills you might get by. But any hills will kill your mileage. Best cheapest way to gain your 2-3 mpg is just drive slower. |
2005 s-10
Does it make a difference if it is a 6 cly or a 4 cly. I live in Illinois so it is mainly flat land not too many big hills too speak of although their are a few. Will the 3:73 save me any mileage at all versus the 4:10 stock that I have now?
If you want to see the difference that different gears make then put on some taller tires. Some tire 4" taller than yours will drop your rpm to 2500. Some 265 75 15's will do the trick.
And it does make a difference whether 4 or 6 cylinder. Torque of the 6 is higher. Will pull a taller gear better. |
An old trick is to install a vacuum gauge in your cab. Accelerate from a stop and watch the vac gauge. If the vac drops significantly, you're accelerating too quickly for efficiency's sake. This is a VERY old idea, thats been revamped with GPS and other sensors as a 'Driving Coach'.
You can also try things like: taller, narrower tires; different oils, high flow catalytic converter and mandrel bent pipe; the proper ignition system, not using your A/C and ditching things like the spare tire and A/C parts for lighter overall weight. These will produce gains (most likely small) If you spend a significant time on the highway; 65mph is probably best. Some googling might produce Airdams for aerodynamics (not downforce). Conventional wisdom says tonneau cover, but there was some tests done on a TV show that an open bed on a truck actually creates a 'bubble' that helps the airflow coming off the roof of the truck. This will probably be more for your amusement than money saved. |
| need HELP with 2003 Landrover | jrm123180 | Suspension - Brakes - Steering | 0 | 03-10-2010 08:38 AM |
| 95 Chevrolet rearend in an 86 Chevrolet? | kvsbmsdws | Transmission - Rearend | 1 | 01-03-2008 12:11 PM |
| 2003 chevrolet silverado instrument panel | roger warmath | Electrical | 1 | 09-10-2007 03:46 PM |
| BAck To The 50's 2003 | hot_rod_kid | Hotrodders' Lounge | 3 | 06-24-2003 12:46 PM |
| BAck To The 50's 2003 | hot_rod_kid | Hotrodders' Lounge | 1 | 06-24-2003 12:11 AM |
