2003 chevrolet silverado instrument panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 01:06 PM
does anyone know how to check out the instrument panel on my truck? got in today and nothing works. could this be a main fuse somewhere? everything else works on truck etc radio and radio controls on steering wheel
but nothing works co-ordinated with the instrument panel.
Old 09-10-2007, 04:46 PM
Most likely sources are a bad ground for the panel, blown main fuse (but it seems like there would be more than one fuse for the panel), or a main plug that has come apart. Power for the panel may also be controlled by a power relay, so it might also be a bad relay.
I'd get out your fuse box diagram and start looking for a very large amp fuse. On that vintage of truck I think there are at least two 50 or 60 amp fuses in a box mounted under the hood.
The good thing about a problem like this is that its probably very easily fixable, and it may not cost much to buy a new relay or fuse, or to reconnect a plug or ground wire. However, in the meantime you don't have a working instrument panel.
Good luck,
Bruce
Welding a panel in place Quarter Flash Body - Exterior 6 03-22-2007 03:56 AM
Help! What To Do With These GIGANTIC Dents!? mistermuscles Body - Exterior 14 09-16-2005 06:24 AM
wanted: an answer to a simple question ikeaguirre14 Body - Exterior 4 05-15-2005 08:23 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 11:36 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
