2003 Chevy 4X4 DIESEL HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2008, 05:54 PM
THE ROOSTER's Avatar
New Member
2003 - 6.6 turbo diesel in chevy pickup - 4x4. Belongs to my neighbor. He got out of it yesterday, no problems. Drove it today and had no power steering or power brakes. No warning lights came on! Anyone familar with a problem like this?
LOUD BOATS SAVE LIVES!!!
LIVIN LIFE A 1/4 MILE AT A TIME
ANYTHING ELSE, WOULD BE UNCIVILIZED!!!
Old 04-15-2008, 07:03 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I know it sounds like it sounds but did he check the fluid..that is a hydroboost on a diesel pickup and if there is no fluid in the powere steering pump then nothing will work.. Could be the pump has failed as well as the power steering pump runs all of that..I would start there..Fill the reservoir and crack a line to see if the pump is pumping..Another thing to look at..
Sam
Old 04-15-2008, 07:05 PM
Last wiki edit: Quadrajet
Wiki Edits: 7
Not real sure what single problem could have caused that... Strange. This may be a stupid question but have you checked the fluid in the powersteering? I'm jumping to conclusions here but could someone have sabotaged the truck just to mess with him? I know that technology has come a long way from the vehicles I'm used to working on but I think that the power brakes still use vacuum to do the boosting.
An easy way to check if vacuum is being applied to the break system is to turn the engine off. Then press and release the break pedal several times. Hold down the break pedal and then fire the engine. If the break system has a vacuum supply the pedal should go soft. If not then you need to run down the vacuum line.
Old 04-15-2008, 07:08 PM
Wiki Edits: 7
I'm an idiot!
I didn't look at your post closley enough. Diesel engines don't use vacuum! Look at the following quote.
"HYDROBOOST POWER BRAKE SYSTEMS - Diesel engines do not create enough useable vacuum to actuate the vacuum power brake booster. The alternative is a hydraulic-assisted power brake boosteror hydrobcmst. This system is currently found in the1 1/4-ton CUCV and the 3/4-ton CUCV Blazer, both powered by the 366 cubic inch V8 General Motorsdiesel engine. Both units are found throughout the NCF and at some public works stations. The hydroboost uses hydraulic pressure developed by the power steering"
Check the fluid first. If it's full the pump may be shot
Old 04-15-2008, 08:29 PM
Wiki Edits: 3
Would be interesting to hear what the problem turned out to be??
Sam
Old 04-15-2008, 08:45 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
This is a very informative site that may help you out:
http://www.babcox.com/editorial/bf/bf030542.htm
It's not just diesel pickups that use Hydroboost systems. I know that at least the 3/4 ton and up gas powered GM pickups also use Hydroboost. My gas '00 Silverado has it, my friends gas 97 has it and my uncles '93 Suburban, also gas, uses it. It works great.
Old 04-16-2008, 07:01 PM
New Member
THANKS TO ALL!!!
It turned out to be the power steering pump, and my neighbor also is having the boost valve replaced!!!
Nuts about 4x4 Chevy Trucks! 82chevyon38s Introduce Yourself 2 03-21-2007 07:51 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
2003 Chevy Tahoe - 'Check Brake Booster' light? mike 96 ws6 Suspension - Brakes - Steering 3 11-27-2005 05:39 PM
swapping a 700r4 with a turbo 350 on 4x4 chevy trucklover Transmission - Rearend 3 12-22-2002 06:39 PM
4x4 chevy jimmy stuck in 4 whl drv speedpro Transmission - Rearend 4 11-19-2002 02:06 PM
