I know it sounds like it sounds but did he check the fluid..that is a hydroboost on a diesel pickup and if there is no fluid in the powere steering pump then nothing will work.. Could be the pump has failed as well as the power steering pump runs all of that..I would start there..Fill the reservoir and crack a line to see if the pump is pumping..Another thing to look at..
Sam
