2003 Impala question about temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 12:37 PM
Hello,
Yes, I know, it is not a question about hot rodding, but there is so much knowledge on this forum, someone probably knows the answer!
The temperature gauge on a 2003 Chevy Impala is dead, the needle is stuck at 1/4, whether the engine is running or not. OK, I can live with that!
My question is whether this has (or will have) an effect on the proper running of the engine?
I believe that the temp sensor for the ECM, is different from the temp sensor for the gauge (so it should not be an issue), but just would like to make sure!
Thanks!
Old 01-15-2011, 01:01 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Hi wave. The sender is seperate from the ecm temp sender. My alldata is not up and running or I could elaborate. The ecm sensor will have a black and yellow wire to it( two wires) . The one for the gauge I think (not 100 percent without checking) is a one wire job. Nice to see you back.
Old 01-15-2011, 01:20 PM
Hi Latech! You are always there with answers!
I am here sometimes, mostly reading and trying to learn new stuff!
Thanks for the answer, that is what I thought, so no issue driving with the dead gauge, good!
Nothing new with the EFI Suburban, it is WAY too cold here, we are hitting a HIGH of -11F today, soooo.....
Old 01-15-2011, 01:25 PM
LATECH's Avatar
Brrrrrrrrrrrrrrrrrrrrrrrrr.
Old 01-15-2011, 05:38 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You still may want to check if the engine is getting up to operating temperature.
If the heater is working OK you should be good.
I though +11 was cold. Yikes
vicrod
Old 01-15-2011, 07:27 PM
75gmck25's Avatar
If you have someone with a good scanner, they should be able to get the temp reading from the OBD port That will verify the temp that is being reported to the computer by that sensor.
Some of the GM and Ford vehicles have finicky stepper motors in the gauges, and the motors eventually have to be replaced because they are so inaccurate. The stepper motors are cheap (8$ each), but you have to disassemble the cluster to replace them. I'm not sure that applies to your 2003.
Bruce
Old 01-15-2011, 08:54 PM
dklong's Avatar
like 75gmck25 said use a scanner with live data to get your temp reading, the temp senser can be a single wire or a 3 wire senser, it maybe a bad senser or a bad instrument cluster or a bad bcm
oil temp gauge fiscus Engine 7 10-21-2007 01:09 PM
transmission temp gauge 1983blazer Engine 2 03-31-2006 08:03 AM
temp gauge steve t Engine 5 04-14-2005 07:48 PM
Question about Temp-gauge not working??? Robbie Engine 4 06-13-2004 07:47 PM
Temp gauge grandprix601 Electrical 2 03-17-2004 08:45 AM
