-   -   2003 malibu wont start after running fine. (http://www.hotrodders.com/forum/2003-malibu-wont-start-after-running-fine-228626.html)
tesiemitt 01-20-2013 02:05 PM
my 2003 malibu will start and run fine when the motor is cold. but after turning car off it will not start again for at least 15-30 minutes. the gas is full, battery fine, no codes are found. and no theft security light is on. I was told this may be the PCM, but am unsure. Any ideas?
Richiehd 01-20-2013 02:31 PM
Don't start? No Crank or no spark? Tell us more, What motor? Could be anything , battery, timing, grounds, lets narrow it down.
tesiemitt 01-20-2013 02:45 PM
this is a 3.1 2003 malibu. the battery is fine, the car will restart after sitting for 15-30 minutes. There are no lights on the dash(ex: theft security light or check engine light.) there are no codes displayed when hooked up to computer. The car cranks but does not start until after sitting .
tesiemitt 01-20-2013 02:46 PM
I was told by someone to replace the PCM, but want to check since theft security light is not on.
Richiehd 01-20-2013 07:11 PM
Did you test for spark? Do you have injector pulse? Does the fuel pump run?
cdminter59 01-20-2013 08:41 PM
Test the fuel pump and the fuel pressure regulator. If they both check out fine read this article you may want to try this. GM Passlock Security Fix
