2003 malibu wont start after running fine. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 02:05 PM
my 2003 malibu will start and run fine when the motor is cold. but after turning car off it will not start again for at least 15-30 minutes. the gas is full, battery fine, no codes are found. and no theft security light is on. I was told this may be the PCM, but am unsure. Any ideas?
Old 01-20-2013, 02:31 PM
Richiehd's Avatar
JS-70
Don't start? No Crank or no spark? Tell us more, What motor? Could be anything , battery, timing, grounds, lets narrow it down.
The Following User Says Thank You to Richiehd For This Useful Post:
tesiemitt (01-20-2013)
Old 01-20-2013, 02:45 PM
this is a 3.1 2003 malibu. the battery is fine, the car will restart after sitting for 15-30 minutes. There are no lights on the dash(ex: theft security light or check engine light.) there are no codes displayed when hooked up to computer. The car cranks but does not start until after sitting .
Old 01-20-2013, 02:46 PM
I was told by someone to replace the PCM, but want to check since theft security light is not on.
Old 01-20-2013, 07:11 PM
Richiehd's Avatar
JS-70
Did you test for spark? Do you have injector pulse? Does the fuel pump run?
tesiemitt (01-21-2013)
Old 01-20-2013, 08:41 PM
Test the fuel pump and the fuel pressure regulator. If they both check out fine read this article you may want to try this. GM Passlock Security Fix
The Following User Says Thank You to cdminter59 For This Useful Post:
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
edelbrock pro flo injection wont start after running out of fuel jemonah Engine 3 11-20-2009 03:59 PM
Sunfire, died and wont start back, fuel pump is running, no gas getting to filter jordan2011 Engine 6 04-21-2008 06:01 AM
700r4 wont shift out of 1 works fine in rev 1988 gmc sub chass Transmission - Rearend 7 08-03-2006 08:46 AM
Cranks Fine..Wont die? SpeedCrazee Electrical 3 05-28-2004 07:44 AM
