2004 Chev Van 6.0 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 05:57 PM
2004 Chev Van 6.0
Problems with 6.0 no oil pressure and 2 cylinders missing with no compression. Found out taking it apart cam bearing slid out and got hooked under lifter don't know if this is a problem or not never seen anything like this before.
Old 04-12-2013, 07:49 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If the cam bearing came out of it's bore, you definitely have a problem with oil pressure. Lodging itself under a lifter is another problem, with the lobe and lifter. I'm assuming the valve never closed completely when running...
Wait, am I on Candid Camera?
Semper Fi
Old 04-13-2013, 01:39 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
If your asking if that is a common problem with 6.0's,it isn't.
window will not go up 1995 chev astro van angel85lx Electrical 4 08-15-2010 12:40 AM
Chev van rear end questions special-k Transmission - Rearend 4 10-16-2009 07:19 PM
1967 Chev Van CHRISJEN Engine 3 07-15-2007 10:07 PM
Steering Column fm 78 Chev Van lazydawg Suspension - Brakes - Steering 1 06-11-2006 01:56 PM
Has anybody used a Chev Astro van booster/master cylinder for the 48 chev truck tomy2tone01 Suspension - Brakes - Steering 2 04-07-2003 06:05 PM
