2004 chevy truck torque converter problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2009, 07:08 PM
i have an 04 chevy p/u 2 wheel drive 1/2 ton. is there anyway to install the torque 180 degrees out of wack so it would not allow fluid to reach the inside of the converter? i having trouble reinstalling the transmission and making it work? i was told to leave the converter on flywheel and install transmission on to it ?... please help me.....
Old 11-15-2009, 07:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what problems do you have?
If you bolted the converter to the flex plate first , then bolted the trans to the engine, you most likely broke the pump in the trans.
NEVER bolt a converter tot he flex plate first ,then bolt up the transmission.
Old 11-15-2009, 08:16 PM
Rexnfx's Avatar
Never ever listen to that person again. That told you to leave the converter hooked to flexplate. They may have even said it because the converter bolts are hard to get to. But all you do is remove the starter to get at em. Most likely the pump in the trans crashed, once the engine was started.
Old 11-15-2009, 08:27 PM
2004 chevy transmission
what would be involved in replacing the pump?
Old 11-16-2009, 02:23 PM
Rexnfx's Avatar
There is many factors to consider. To try to educate someone on the pump replacement. It may look like there is only 7 bolts holding it to the trans. But its pretty involved work. The pump may actually be able to be repaired. By putting a new rotor kit in it. But one also has to inspect it and know what they are looking at, to make it a verified repair. Otherwise, just buying a new/reman pump may cost more than a used transmission.
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 10:16 AM
Chevy Torque Converter Swap! leejoy Transmission - Rearend 7 01-04-2007 05:55 AM
1981 chevy truck HEI ignition problems Brad Wiley Electrical 3 12-29-2006 11:26 AM
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 11:41 AM
Torque converter problems 72elcamino Transmission - Rearend 1 07-03-2004 11:02 PM
