2004 Duramax Rpo - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-25-2006, 11:37 AM
jray's Avatar
Originally Posted by ChevelleSS_LS6
That would suck... lol... diesels are the ultimate sleepers!
As for what to watch for, make sure you're not overpowering the driveline, and watch EGTs. The allison is pretty bulletproof, the stock dodge and ford autoboxes tend to not live well under performance use.
It does teach ya not to go to sleep at the light though!
  #17 (permalink)
Old 10-25-2006, 04:24 PM
Originally Posted by RPMs
The Allison trans, if it slips tells the puter to turn the fuel off so the trans does not get burned up. They call this limp mode. On your surge, you might try to change the fuel filter.
You can no doubt feel it.......you can limp the engine (codeP1093), which is fuel related and you can limp the tranny, which I did............high gear is the worst, especially when or if it tries to downshift in full throttle...........I was in 5th at about 90MPH, then BOOM..............shifts into 3rd and stays there.......say shift inhibited on dash.........I knew what it was after I gained control of my bodily functions, as there had been many of the local Dmax guys who had warned me about it............this is how the tranny saves itself.............scarry, but it will let you get home...............shut truck off a short bit........come back out...........all is well when restarted......convertor is the weak link 1st, then clutches.......best of luck.......Brad
  #18 (permalink)
Old 10-25-2006, 07:41 PM
Ya...that is scary, save the tranny blow the motor. Its awesome I can look around the internet and never find what I want, all I gotta do here is ask a question and maybe in an hour or so I get all the info I need. Hotrodders...IS BEAUTIFUL! Thanks a lot guys.
Diesel engine oil,assembly lube and flat tappet cams 78 monte Engine 7 06-19-2006 10:01 PM
Ethanol yea or nay hotrodgrasshopper Hotrodders' Lounge 30 03-30-2006 12:54 AM
2004 Hemi V.S. 2004 R/T Adrenaline_Fiend Hotrodders' Lounge 26 05-12-2005 01:25 PM
Look What's Coming On Monster Garage!!!!!!!!!!!!!!! willys36@aol.com Hotrodders' Lounge 10 01-20-2004 09:17 AM
