2004 Jeep Grand Cherokee keyless entry - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 07:42 AM
DENCOUCH's Avatar
Keyless entry won't hold programming.
Manual sez to press unlock button six times, and then test it...nothing happens.
I turn the ignition to the "Run" position, and then get things working after a couple of button presses... programming appears to "take" and all buttons on the remote will function.
I turn off the ignition and try it... nothing happens.
Batteries are good in the transmitter and the remote functions according to the remote tester at Auto zone. ideas?
Old 07-22-2011, 01:22 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
The RKE is programmed with a compatible scan tool through the Passenger Door Module (PDM).
The only scan tool that can perform this type of programming is the DRB3. (that I know of)
Hope this helps
Steve
brakes kick back on 93 jeep grand cherokee 36int Suspension - Brakes - Steering 2 05-22-2011 07:39 PM
Cant get hatch open on 93 jeep grand cherokee eric32 Body - Exterior 13 07-18-2009 04:30 PM
1998 Jeep Grand Cherokee Jeeper 4-Ever Transmission - Rearend 3 06-20-2006 07:59 PM
keyless entry astrops Hotrodders' Lounge 1 05-08-2005 09:12 PM
GM keyless entry val Electrical 1 09-17-2003 06:38 PM
