-   -   2004 malibu wheel cylinders (http://www.hotrodders.com/forum/2004-malibu-wheel-cylinders-181874.html)
ss396si 07-30-2010 08:12 AM
I know this is not a hot rod but i want to install new rear wheel cylinders. I need a special socket to remove the wheel cylinder bolts, the bolt looks like a star. Where can i find that tool?
MARTINSR 07-30-2010 08:26 AM
At any REAL parts store (not the "McParts" stores like Pep boys or AutoZone) will have them. They are called "Torx".
ss396si 07-30-2010 08:32 AM
I think Sears should have a set of tork sockets
Thanks
MARTINSR 07-30-2010 09:32 AM
Yes they would. Now, mind you, I don't know for SURE that this is what the car uses. It could have some odd ball bolt that needs a special tool. Earlier Malibus for instance used a clip to hold the wheel cyl in and it is a pain in the ars without a special tool designed JUST for this.
It could also be a female torx, so get over to the Sears store and look at what they have to see if it makes sense.
