2004 Silverado electric speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2008, 10:43 AM
Has anyone else had a problem with their electric speedometer in their GM vehicles? The factory speedometer in my 2004 Silverado goes crazy when the temperature drops below 40 degrees. Above 40 degrees or so ... no problems. The odometer works like it should even when the speed indication is off. The speedometer is usually high by 30 to 40 MPH ... when it goes crazy.
When the temperature is above 40 degrees ... the speedometer works as it should. I do not want to have to move to Miami ... to have a accurate speedometer
Thanks in advance
Deuce
Old 10-25-2008, 07:11 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The only thing the one in my '00 Silverado does is jump to 60 once it hits 55. Other than that it works fine.
Old 10-26-2008, 08:14 AM
speedo
GM did a recall on these- the clusters were replaced free if less than 75000
miles- maybe this is one that was bad. Check w dealer if yours was replaced.
Old 10-26-2008, 08:50 AM
I bought the Silverado new ... so I know it has not been replaced. But I am over the 75,000 mile mark now
I did not get the recall notice
Thanks jetnow1 ... for the info
Deuce
Old 10-26-2008, 12:57 PM
speedo
Depending on how much you are over- try talking to your dealer- with GM's
sales as bad as they are they will not want to lose a customer over something
you did not get. Worth a try. Jim
Old 10-27-2008, 06:23 PM
302 Z28's Avatar
We didn't get a recall notice either on our 04 Tahoe. The speedo just slowly quit working, then the tach. Took it in under GM Extended protection plan (60,000 miles) and the service writer told me of the recall. I would take it in anyway and raise hell. That speedo/gage cluster is about $800 I was told.
No part number was listed on the repair receipt I have, just says "Replaced & programmed instrument cluster as per special policy"
Vince
Old 10-27-2008, 06:49 PM
My 04 is at 112 thousand ... ( 5 trips to California from here in the Carolinas ... and staying out west for a few weeks each trip ) ... adds up.
I will go speak with my dealer ... I have bought 5 or 6 new cars/trucks from him. Almost bought a new 08 about a month ago ... but he could not find a 08 with the equipment I want. He thinks I am going to order a 09 ... so he may bend the rules a little
Thanks for ALL the info.
Old 10-27-2008, 09:15 PM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
Deuce,
My 04 Avalanche did something similar....but they replaced it under waranty.
I've got a question for you....I'll PM you though.
Dave G
Old 10-28-2008, 07:04 AM
302 Z28's Avatar
Randy you may be able to remove the gage cluster and clean the contact surfaces where it plugs into the wiring harness. I have heard sometimes that fixes the issue.
Vince
th350 trans to electric speedometer? Hero2112 Electrical 13 02-25-2011 12:32 AM
Electric Speedometer Senders oldcarguy36 Electrical 10 05-08-2010 02:53 PM
2004 Silverado: 4.3L to SBC swap 04SilveradoMykk Engine 8 03-28-2009 11:35 AM
Daytona Speedometer Electric Cable Dee Cercopely General Rodding Tech 2 10-18-2005 03:01 PM
Look What's Coming On Monster Garage!!!!!!!!!!!!!!! willys36@aol.com Hotrodders' Lounge 10 01-20-2004 09:17 AM
