2004 vortec 5.3 water temp problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2013, 01:13 PM
Last journal entry: 81 regal swap project
I got a 2004 z71 with the 5.3 vortec and whenever the outside temp is over about 70 my engine wants to jump around in temp. It usually runs just below 210 I'd guess about 195 or 200 but when it's 70 plus outside it will run up to about 220 which is pushin the safe zone and I'm not racin around and tearin it up. Just cruisin. On the highway whenever I head up a hill temp will rise then go back down to 210ish and in the city whenever I take off from a light or stop sign it will do the same. I just changed my oil today and there is no sign of anti freeze in it and nothing comes out of the exhaust and the coolant level has not changed... I've burped the cooling system to make sure all the air is out of it... Could it be just a thermostat or somethin more serious like a head problem or intake issue? Any help would be great. Thank you
Old 05-13-2013, 05:25 PM
More likely the radiator no longer moves enough coolant through the core, it's just crudded up with the stuff that collects in old cooling systems. It has Dexcool in it, this will be messy to fix. Probably the radiator will have to be replaced. All traces of Dexcool throughly flushed from the engine, heater core and all lines. Once clean you can go back to a mixture of Prestone and distilled or de-ionized water.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
4x4Chevy (05-29-2013)
Old 05-14-2013, 10:13 AM
I am gonna try that. I never would have thought about that thank you!
Old 05-29-2013, 06:58 PM
That worked out great! Thank you for the advice
cooling, head, intake, temperature, thermostat
water temp tylerrosario1234 Engine 3 07-26-2011 12:27 PM
2004 chevy truck torque converter problems? cabledawg22000 Transmission - Rearend 4 11-16-2009 02:23 PM
water temp on sbc zephyrc Engine 17 02-18-2007 10:34 AM
Water temp varies?? Mudstomper Engine 5 03-12-2003 04:18 PM
Water temp. Jeff Christenson Engine 9 02-20-2003 07:44 PM
