Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2004R /700R4 TV cable adjustment
Old 11-23-2010, 09:45 AM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
One thing to make sure of (it is in some of the links) is to have the correct geometry on the throttle plate crank arm. You did not mention that you had this covered, if you do then good...my moot point.
TCI and others sell the correct crank arms for holley/edelbrock carbs. This ensures the correct rate of pull on the TV cable vs throttle position and is critical.
