-   -   2004R /700R4 TV cable adjustment (http://www.hotrodders.com/forum/2004r-700r4-tv-cable-adjustment-187773.html)
72bluemalibu 11-16-2010 06:24 PM
Anyone have knowledge of proper TV cable adjustment for the 2004R or the 700R4 trnsmissions. I think you should have full boost before WOT. I have a Art Carr 2004R behind a BBC w/ 550HP. I don't want to fry it.
cool rockin daddy 11-16-2010 06:28 PM
Would be BEST to call Art Carr to make sure. They built the trans. Next would be to post this in the transmission forum.
RippinRon 11-16-2010 06:32 PM
Have a looky here.
bubbahotep 11-16-2010 07:25 PM
These instructs seem easier to follow: link
So long as you hear it CLICK when you do WOT 1 time, its set. It wont snap out anymore after that, its set.
345 desoto 11-23-2010 06:55 AM
THIS is what finally did it for me! I searched/read everything I could find on adjusting my TV cable, but nothing seemed to work...until I ran onto this...ESPECIALLY the last paragraph about setting the cable about 1/4" out...
http://www.chevyasylum.com/tech/tvcable.html :welcome:
Custom10 11-23-2010 08:45 AM
One thing to make sure of (it is in some of the links) is to have the correct geometry on the throttle plate crank arm. You did not mention that you had this covered, if you do then good...my moot point.
TCI and others sell the correct crank arms for holley/edelbrock carbs. This ensures the correct rate of pull on the TV cable vs throttle position and is critical.
RippinRon 11-23-2010 09:42 AM
Here is a good read and explains how to do it by measuring transmission pressure. Warning its a little colorful and hard to follow.
