2004r sources? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2004, 07:44 AM
2004r sources?
I have a daily driven '64 Chevy Biscayne that currently has a bone stock 230/powerglide/3.08 rear. I have been thinking about a 2004r swap for better highway mileage and a more relaxed cruising at today's highway speeds. (My commute has 20+ miles of 75 mph interstate... 3000rpm!) I know that the g-bodys with od used the 200 (not the 700). Any others? s-10's, Astros, caprice? I know that one from a Chevy powered car will work. I have also heard that some (or all) of the Buick/olds/pontiac bolt pattern 200r4 trannys had dual bolt patterns and will also fit a chevy block. Any truth to this?
Old 04-16-2004, 08:07 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Caprice 85 and prior did not come with 2004Rs. 86 Caprices had them, 87,88,89 probably did too.
Old 04-16-2004, 09:06 AM
A friend of a friend has an '86 Pontiac Parisiene (sp) same as Caprice with a 4.3 v-6. I've driven it in the past (7-8 years ago) and dont remember if it had OD or not. So, it should be a 2004r assuming it's overdrive at all, right? I can get this car for little or nothing, and it has very low miles on a rebuilt tranny. It was parked 4 years ago due to a differential failure, and rust problems. (well' the ol' 4.3 was pretty tired too, seems to me the car has 250,000+ miles on it, but only 10,000 or so on the rebuilt tranny). Unfortunately, the car is stored 300 miles from my house, and I don't have anyone reliable to check if it's even an OD tranny. If I can confirm it, I can make the trip myself, and bring back the engine and the tranny... (i've been thiking about a TBI conversion on the inline 6 in my car)
Old 04-16-2004, 09:40 AM
Re: 2004r sources?
With either a 200-4R or a 700-R4 and a 3.08 rear end........you will be geared so high that the poor little six will have trouble pulling that BIG Biscayne.
The 200-4R has 33% overdrive.
The 700-R4 has 30% overdrive.
You must have a short 26 or so inch tall tire on the Biscayne.
200-4R......3.08 minus 33% = 2.063 (in overdrive)
700-R4......3.08 minus 30% = 2.156 (in overdrive)
I would buy two 15" rims and a 235X75 tire that was 29 to 30 inches tall and cut the RPM's that way.
3.08 X 75 mph X 336 divided by 30 tall tire is 25,872 RPMs.
DEUCE....General Rodding Tech Moderator........
PS. The tire change will affect the correctness of your speedometer
Old 04-16-2004, 12:57 PM
If you can find it, any(or atleast most) olds made 200-4Rs came with the dual bolt pattern.
Old 04-16-2004, 01:31 PM
poncho62's Avatar
Wiki Edits: 5
If installing an o/d trans in your "X" framed Chevy, you are going to have to shorten the driveshaft, and possibly move the crossmember. Not a lot of room under there. I would go the taller tire routine. If you want more gears, use a 70s turbo 350. Thats what I put in my 62 Canadian Pontiac..It has the Chevy "X" frame and drivetrain.
I also have 275x60x15 tires. works good.....
Old 04-16-2004, 01:41 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Most BOP 2004Rs have dual pattern. I got mine for my '53 Chevy pickup w/ 235 six out of a '85 Pontiac station wagon. I am using a Stovebolt Engine Co. tranny adapter.
Old 04-16-2004, 06:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool HOW many RPM'S ?
=========== that RPM figure seems a bit HIGH to me.
Old 04-16-2004, 07:53 PM
Re: HOW many RPM'S ?
OK..............I placed the coma in the wrong place.......
That is a LITTLE high isn't Crosley ??
Bad eyes, no coffee and been up all night...sorry
Old 04-17-2004, 08:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool Re: Re: HOW many RPM'S ?
==== I guess if the motor was a gas turbine the RPM would be OK...
I dont drink coffee.... gives me the "wind"
Old 04-19-2004, 05:40 AM
airworld2's Avatar
200r4
200 r4 has been around since 81 first car I noticed it used in was 1981 caprice s/w was a taxi cap
airworld2
Old 04-19-2004, 06:10 AM
Re: Re: 2004r sources?
Somehow I think the 200-4R has a bit better geaing to it than a 2 speed powerglide
In fact the 200-4R has a much better 1st ratio than the 350 or 400, so you'd be much better off.
