2004r test ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2013, 10:41 AM
454 Rattler's Avatar
NEVER SATISFIED !!
2004r test ?
I blew a line on my trans and ran it dry. The only way to get home was by adding fluid. I was 15 miles from home so I had to refill 3 times. I've repaired the line and changed the filter and gasket.
Nothing looked unusual and I've driven it twice since then with no real problems.
Is there any way to test the trans in the car ? I can't drive it now cause we have snow on the roads now till April.
Thanks for any thoughts and help.
454 RATTLER
Old 11-09-2013, 05:03 PM
NEVER SATISFIED !!
Thanks for your reply F-BIRD'88. At least now I can relax till spring when I can drive it again.
454 RATTLER
Old 11-11-2013, 03:08 PM
How big a leak, and where. I would think you'd loose all that fluid within a mile. I read that when they have had the 200 4r on the dyno, they would pump about a gallon per minute.
Old 11-11-2013, 04:59 PM
NEVER SATISFIED !!
The leak was in a rubber trans line connecting the trans to the cooler. The cooler is located on the frame under the riders side of the car .
The rubber was only about 4 inches long. It split between the double hose clamps I used on each end.
I used it because of the chance of vibration. The split was less than a quarter inch long.
454 RATTLER
Old 11-11-2013, 10:13 PM
lThat is the same location I've got my coolers for my 200 4r on my nova. Just for knowledge, did you figure out what the cause was? My hoses are a little over a foot long. I have barbed brass fittings that come out and into the tranny that are like the ones that go into the coolers. One hose goes threw the frame rail and the other loops in front of frame rail. The hole in the frame is large enough that I was able to use a section of larger hose for a grommet. Had to lower mine down a little because they would bleed back into the pan and over flow. But got that solved.
Old 11-12-2013, 09:52 AM
NEVER SATISFIED !!
We really don't know what caused the split in the hose.
There was less than 200 miles on the brand new hose, no kinks and nothing rubbing.
The hose wasn't the cheap hardware stuff either. I used the same fittings as you did and the split was about half way between them.
I left the car sitting on a sheet of plastic overnight before spending the next day cleaning the under side to get the trans fluid off.
What a mess that was !!
454 RATTLER
Old 11-12-2013, 09:06 PM
Mine is put away for the winter. I might get it out once sometime before spring, just to keep it running good. Got mine running with good hose because I was worried about the radiator not cooling the fluid enough and two large coolers also give me fluid quantity along with the deep pan. I'll keep an eye on mine every time I look it over.
compression test and leakdown test? crussell85 Engine 7 07-26-2013 03:58 PM
2004R Test drive w/Video: Opinions Needed? Steven's 72 Transmission - Rearend 2 06-17-2013 10:23 AM
2004r mitchc Transmission - Rearend 7 09-04-2007 09:03 AM
CBD test (car buying disease test) pigjamelectric Hotrodders' Lounge 8 02-11-2007 06:05 PM
2004r ?? caminocrazy1984 Transmission - Rearend 10 05-02-2006 04:23 AM
