what rear gears do you have in your car? I would do everything I could to keep that 200 in it, that overdrive is really nice. Plus it uses less power, weighs less and has a lower first gear. If you trans is slipping you need to diagnose that first, clutches are probably the first thing you'd think about.
Why not just freshen up the 200? Get a nice, new, aluminum pan for it and a rebuild kit and do it up! K |
I'd fix the 200 but you seem determined. Crossmember stays where it is but you'll need to shorten your driveshaft and change the yoke or get the correct Vette TH400 shaft. You'll also need to add the kickdown switch under the dash as TH400's used electric kickdown. That's all I can think of right now.
my buddy did the 400 to 200r4 swap in his 75 vette. he didnt need to change the length of his drive shaft, his flywheel bolted up fine from one to the other, the only other thing is the shifter will have to converted to a 3 speed set up and the detent set up, not a hard swap, go for it, the 400 can take a beeting.
Thanks for the replies guys I know about the switch under the dash just forgot to post it. Ive had this car almost 2 years and this trans has NEVER been right. Ive set the TV system until I was blue in the face, Taken numerous pressure readings So i know the TV is set up right. It seems to be very sporadic<SP> sloppy shifts, hard shifts, late shifts, in OD by 25 MPH some times it dosent go into OD at all..and some days it works like a champ at this point im pretty discouraged. I got the 400 at a good price from a reputible source and its already been rebuilt I know about the weight the gear ratio and the lower power useage..I didnt just jump into this its been something ive been thinking about for a while..
You guys have been good to me in the past. Just wanted to see if I was gonna run into probs. thanks for the driveshaft/tailshaft info |
While the 200-4R and TH400 share the location of the rear mount and appear to be the same length the 200-4R is the same overall length as a short shaft TH350, the short shaft TH400 is about 7/8" longer. The TH350, 200-4R and 700R4 use a 27 spline output shaft and yoke the TH400 uses a 32 spline yoke. It would be possible to go from a TH400 to a 200-4R using the same shaft by changing the yoke although it wouldn't engage the tailshaft as much and I don't think I'd like that but I'm sure people do it all the time and get by with it. However if you're switching from a car that was originally equipped with a TH350 and still has the TH350 driveshaft you better shorten it for the TH400 swap or you run the risk of binding against the tailhousing. I switched from a TH350 in a '72 Chevelle to a TH400 and while I could have physically installed the 350 shaft by simply swapping yokes the first time the rear suspension made any significant movement bad things would have happened. I understand a Chevelle is not a Corvette and that may not be an issue with IRS but I'd still check the driveshaft fit up VERY closely. Now if screamin340's car was originally equipped with a TH400 and they kept the 400 driveshaft then all you need to do is switch it back to the TH400 32 spline yoke. |
| th350 - th400 tranny swap | gilby246 | Transmission - Rearend | 2 | 03-23-2005 05:08 PM |
| What's needed for a th350 to a th400 swap? | Fil | Transmission - Rearend | 2 | 09-16-2004 02:09 PM |
| TH400 Swap | 79454 | Transmission - Rearend | 3 | 01-03-2004 07:35 PM |
| 4L80 to TH400 swap | Jason | Transmission - Rearend | 4 | 06-14-2003 06:46 PM |
