2004R & Turbo 400 Mounting question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2009, 08:01 PM
miles's Avatar
2004R & Turbo 400 Mounting question.Blown 455 Olds
Getting ready to weld my engine and tranny mounts in 40 Ford coupe, Im running a Blown 455 Olds with Turbo 400 but have decided to go with a 2004R. My question is , are the tranny mounts the same, would like to get it all mock up and welded in tonight and get the 2004R at a later date.
Thanks Miles
Old 09-04-2009, 08:44 PM
artsvettes's Avatar
You should be good. The face to mount is the same
Old 09-04-2009, 11:31 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
According to this: http://www.tciauto.com/Products/TechInfo/trans_dims.asp
Probably not.
Three different TH400 overall lenghts. Two shared the same bell face to mount spec.
Old 09-05-2009, 06:37 AM
artsvettes's Avatar
Yes he may need to address the driveshaft later. But he asked about the mount which remains the same.
Old 09-05-2009, 09:03 AM
It depends on which TH400. The short tail TH400 (as found in the A-body cars) has the trans mount in the same place as the 200-4R. The long tail TH400s (as found in the full size cars) has the trans mount further back. Did you happen to pull that 455 and TH400 from a Delta 88 or 98? If so, the trans mount is likely in a different place than on the 200-4R.
Old 09-05-2009, 12:13 PM
miles's Avatar
Thanks guys for all your replies. and yes the engine and tranny was pulled from a 1980 Delta 88 which has the longer tail shaft so I guess I better just wait until I get the 2004r before I start welding.
Miles
Old 09-05-2009, 12:59 PM
Miles
A 455 and TH400 would not have been stock in a 1980 D88 - the last year of 455 production was 1976. You had better get a tape measure or check the ID tags and figure out what you really have.
i know i know another turbo question. r1967a Engine 9 02-12-2007 02:02 PM
Turbo and external waste gate question. help please beemdubya Engine 2 11-21-2006 07:35 AM
TH-350 vs Turbo 400 leejoy Transmission - Rearend 13 01-05-2006 01:34 PM
Turbo 400 Question MAD BOWTIE Transmission - Rearend 10 12-20-2005 06:49 AM
Question about Turbo 400 Requiem Transmission - Rearend 2 01-31-2002 07:52 AM
