2004r vs trubo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2002, 01:03 PM
Post 2004r vs trubo 350
Does anyone know if a turbo 350 and a 2004r are anywhere near the same dementions . What are the differences size wise.
Old 06-18-2002, 01:18 PM
New Member
Post
Gerry,
Check out the following:
http://www.hotrodssuperstore.com/trandim.html
Has dimensions on a bunch of Ford, Chevy, & Chrysler trannys
Don
Old 06-18-2002, 08:32 PM
E.T. divided by $ spent= Speed
Post
Hi I yanked the 200r4 from my old 85 monte and replaced it w/ a th350.All I had to do was move the crossmember forward cause the mount is inj a differant place.Also had to run a vacuum line for the modulator.
Old 05-19-2003, 09:20 AM
Post
Hehe,
I just yanked a TH350 from my '67 Camaro in favor of a built 2004R with a 2200 stall lock-up converter. I had to change the crossmember and the cooling lines. But that was it. Awesome.
I love the overdrive. And the lower first gear is cool... Did I say I love the O/D? My engine's turning like 1200 rpm at 50 mph, which is a typical cruising speed where I live. Also, the gas mileage is noticeably better.
It bolted right in. Speedo cable went right on. My B&M megashifter mated seamlessly. No prob with the driveshaft either.
I did have to buy a TV cable bracket setup <a href="http://www.tvmadeez.com/" target="_blank">http://www.tvmadeez.com/</a> for about $90. And it took a little work to get the trans to behave the way I like.
The tranny I bought is built to hold up to 600 hp and shifts firmly, a stage 3 from <a href="http://www.bowtieoverdrives.com" target="_blank">www.bowtieoverdrives.com</a> . Unless you're going pure drag race, I believe the OD tranny is better than the TH350.
My 2
Roy
