2005 Acura RSX door skin replacement question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 01:35 PM
cyclopsblown34's Avatar
Colorsanding painter
One of my client's son has a 2005 RSX that needs the door skin replaced and I have no clue of what is involved. I'm assuming the door is bolted to the body and the skin gets replaced just like any other skin I've replaced. Grind off the edge, pull the old skin, line up the new skin, structural adhesive on the door frame where the skin will contact it, fold the edges over and weld or glue them in place. The thousand or so miles between me and it are hampering my effort to get them a ballpark figure. It will be here in July for the work. Am I correct in my guess? Where to buy quality door skins? SortaFit?
Thanks, Chip.
Old 03-25-2009, 01:43 PM
That is "all there is" to it!
Buy the skin from Acura and no where else. The skin is about $325. If you aren't doing this stuff on a regular basis and have the tools sitting right there for you, I HIGHLY recommend a good used door. It may cost you more unless you can find a bare one, but I HIGHLY recommend it. The new shell is about $800.
Old 03-25-2009, 01:46 PM
Hammers, dollies, vise grip assortment, welder and Loctite adhesive dispensers. I've never replaced a skin on anything newer than a 70 Chevelle.
Old 03-25-2009, 01:53 PM
That Acura skin is like bolting on a license plate compared to a skin on a 70 Chevelle! EVERYTHING about that job is easier!
Buy the new Acura one, (I doubt there is aftermarket anyway) and don't clean up all the sealer or paint on the corners on the back side. When you get the new skin on you can fold it right over and see where the old one was. I am not kidding you, I know guys who will install skins like htat without even trial fitting the door before paint!
I would have a knot in my stomach if I did that, so I will always trial fit it after hemming the skin just to be sure. And sure enough VERY seldom does it need any more work.
Old 03-25-2009, 02:01 PM
Brian, your knowledge here and Autobody101 has helped me immensely.
Old 03-26-2009, 05:23 AM
Glad I could be of help. This by the way was the very first "basics" I wrote about 10 years ago! My GOD time flys!
“Basics of Basics” Door skins
By Brian Martin
First off, to remove the old skin, take a grinder and grind the edge door where the skin folds around onto the door shell. Grind until you see the three layers of metal. Don’t worry if you grind a little too much, if the shell gets ground a little it is no big deal. On the spot welds you can drill them or grind them, sometimes both. By grind I mean a die grinder with a cut off wheel, just set the spinning wheel on the weld moving it back and forth till you have cut though eliminating the weld.
To prepare the new skin, take a DA or similar tool and sand the OUTER edge of fold in the new skin a little. I am talking about the edge as it will be folded onto your door shell. If you LIGHTLY sand this edge the lip will fold MUCH easier when you install the skin.
If you don’t plan on bonding the skin on, I highly recommend it. It is a corrosion fighter like none other. With the door sitting on it's back (the interior side down) clean the edge where the panel will bond with an abrasive disc to bare metal. Don't use a grinder, it removes metal. Then you will put a small ribbon of panel adhesive, NOT door skin adhesive but the Panel adhesive, it has a higher strength and longer working time. Spread out the adhesive with a plastic spreader so ALL the bare metal is covered. Then apply another thin ribbon on the inside edge of shell where it folds down towards the interior.
I don't know what primer you will find on the new skin, if you can be assured it is good quality and has bonded well, leave it. If it is questionable, then sand it out and apply a good epoxy primer.
After you have a good primer (or left alone) you need to simply scuff it with a red scuff pad down in the area that will be bonding. And believe me DON'T over do it with the bonding! It WILL go around the other side of the fold without even trying and get on your dolly and hammer!
Lay the skin down on the door and position it. Clamp it down at the top where you won't mess up the outer skin. I used a rubber dolly, if you don't have one take a flat dolly and tape a rag or something on it to provide a little cush. A neat home made dolly for this can be fashioned from a 5" long piece of 2x4 hard wood and a 3M rubber squeege glued to it. Hold the dolly on the top surface right over where you are going to fold the lip, strike up on the fold with your hammer while pushing down on the dolly, strike it at an angle so the metal "wants" to hold and NOT lift the skin off the door.
THE TRICK!...... Don't fold it very much at a time, I mean VERY LITTLE, about an 1/8" MAX, maybe even 1/16". Go around the WHOLE door before folding more. Go around and around until you have it folded down almost flat, about 1/16" from touching.
Turn the door over, being particularly careful not to rest the door in a way that will bend your new skin! Now strike down with the hammer while you are still supporting with the dolly to close up the fold a bit more.
ANOTHER TIP!....DON'T smash it down!!!! Two reasons, one you will distort the outside and two you need to leave the bonding in there for it to work.
STILL ANOTHER TIP!.... Use a number of hammers that closely match the shape of the door, if you are in the rounded area at the top of the door, use a domed hammer.
After all folding is done, fine tune the edge so that there are no high or low spots. You can run a vexin file over these areas to spot highs and lows and cut a LITTLE if you need off of high spots. Then using a DA on grinder mode with a 120 disc you "block" the panel around the edge to perfection.
You can spray a weld thru primer on a couple of inches or so at the corners so you can then weld there and not burn the adhesive. But be ready to trial fit the door and twist it if need be for your weld it. You should always trial fit the door before the adhesive cures and “massage” the door to fit well then weld the corners on the back side so the door can’t twist while the adhesive cures.
If you have any fears of not being able to get the door skin on and folded in the working time of the adhesive, don’t use it! All you need is a little tack weld at each corner on the inside at the folded lip. Just go ahead and prime all the hidden areas and after the skin is on, put a seam sealer on the folded seam and spray a cavity wax or underseal around the seam from the inside.
Read the recommendations on the adhesive you are using, some want the metal bare while other want it to be primed, read the tech sheets.
Hotrodders Guidelines -- READ ME Jon Body - Exterior 0 06-14-2003 06:00 PM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 05:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 05:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 05:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 05:53 PM
