2005 Corvette 6 spd manual with reverse gear problems
C6 2005 Corvette 6 spd manual will not shift all the way into reverse.Where do I make a linkage ajustment.
I edited the thread title since most folks here would think the question is about a Ford C6 automatic transmission, not a Corvette.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Although this video is for the C5 Corvette, the internals are pretty much the same for the C6. The procedure to remove the console in the C6 may be different, but once you get to the shifter alignment pin, the procedure is the same (starting about 7 minutes into the video). This is an easy adjustment to make. Credit to Froggy from some of the Corvette forums. A couple of other things to consider are changing the trans fluid, check the condition of the clutch fluid, and whether the clutch is dragging or not fully disengaging when the pedal is fully depressed. |
| 2005 Corvette/ Noise Rearend | RATCHETHEAD | Transmission - Rearend | 3 | 04-19-2010 03:26 PM |
| T-400 reverse manual valve body problems | huafist | Transmission - Rearend | 11 | 02-25-2010 06:40 AM |
| 5 SPD manual wont install all the way | KevinDeFouw | Transmission - Rearend | 8 | 06-08-2006 06:05 PM |
| Mustang GT 5 spd-no reverse | xntrik | Transmission - Rearend | 4 | 11-22-2005 11:00 PM |
| 2005 Corvette | 66Mustang | Hotrodders' Lounge | 2 | 07-07-2003 11:59 PM |
