2005 Corvette/ Noise Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2010, 01:32 PM
My 05 Vette Makes A Clicking Noise When Backing Up. Kinda Like A Dry Cv Joint. Car Has 17000 Miles.
Old 04-17-2010, 07:56 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It only does it in reverse? Have you checked the rear brake calipers i have seen them make a clicking noise when backing and not foward. JMO
Cole
Old 04-19-2010, 02:42 PM
Clicking Noise In Reverse
Have not checked if brakes cause clicking. What and why would in reverse cause click. Other info from forum on noise was that it was normal due to torsens? Torsens mispelled or torsion. Need more input from blogs etc. Rear does make little noise when sharp slow hard turns, such as from need of additive. any recommendation as to which to add. GM or aftermarket?
Thanks
Old 04-19-2010, 03:26 PM
302 Z28's Avatar
Check the lube level and add if needed, also a bottle of traction additive might help.
Vince
Noise problem with a '02 4L60E w/video clip Jason Transmission - Rearend 6 03-22-2009 06:55 PM
Corvette rearend 30modela Suspension - Brakes - Steering 7 01-09-2007 04:15 AM
Corvette rearend 30modela Transmission - Rearend 1 01-05-2007 06:53 PM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
66 chevy rearend swap with corvette daddyj Transmission - Rearend 2 01-02-2003 09:21 AM
