2005 Ford Ranger manual tranny fitment questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2011, 12:50 PM
does any body know if my stock 05 4.0 ranger manual tranny will bolt up to a 5.0or4.6 engine and if not what tranny will work.
Old 01-10-2011, 07:20 PM
Wiki Edits: 31
No and it will take some work to put the Mod motor in a Ranger. has been done tho... as far as manual transmissions. a T-56 from a Mustang will work, but you will have to cut the floor unless you can find a way to make it mid-shift
Old 01-10-2011, 07:33 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
any time i have a question about anything ranger i start here
http://www.therangerstation.com/tech_library/index.php
i couldnt get their home page to load but heres their tech library
Old 01-10-2011, 08:25 PM
Ranger never had a 5.0 engine, but the Explorer did. However, the 5.0 liter engine in the Explorer was not offered with a manual transmission. I recall hearing that the reason was that the manual drive-train was not strong enough for the torque of the 5 liter engine.
Bruce
2005 ford focus tranny bigrobdog Transmission - Rearend 1 01-25-2010 06:15 AM
Manual steering box for 1991 Ford Ranger Daanii Suspension - Brakes - Steering 2 08-18-2009 10:45 PM
info needed, 5 speed manual , 92 Ford Ranger burnt olds Transmission - Rearend 1 02-07-2008 06:34 PM
Ford Ranger manual steering box ? AC/DC Suspension - Brakes - Steering 12 08-12-2006 06:41 AM
93 Ford Ranger Manual Transmission problems Triaflo Transmission - Rearend 1 08-28-2005 07:58 PM
