2005 gmc 1500 4x4 Swapping transmission, cross member question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2013, 03:56 PM
Im swapping my transmission in my truck, its a 2005 gmc 1500 4x4 with a 4l60e. i have literally everything disconnected and the transmission is sepereated from the motor by about half an inch, i cant remove the transfer case as the top nut/bolt i unaccessible with a wrecng or socket. is it possible to remove the torsion bar crossmember and drop it as one? and how do you remove the cross member? the transfer case rest about 3 inches onto it. some one please help, i go back up north in 2 days for work and need my truck
Old 06-19-2013, 01:05 PM
There's probably more information here then you need but check out the following link.
ECSB 4WD 4l60E to 4l80E - PerformanceTrucks.net Forums
Thanks,
Bobby
98 gmc 1500 transmission noise Bert H Transmission - Rearend 0 04-13-2013 10:36 PM
1994 GMC sierra 1500 4x4 Chevyweighton Transmission - Rearend 2 10-26-2011 02:47 AM
1996 gmc 1500 transmission problems Countryboy01 Transmission - Rearend 4 07-01-2011 03:30 PM
Swapping engines from a 89 blazer 4x4 4.3l t.b.I to a 88 s10 4x4 2.8l t.b.I. The donkey Hotrodding Basics 23 06-28-2011 08:43 PM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
