2005 Silverado 4x4 acting up
Hi guys,
I just got a 2005 Silverado with a intermittent 4x4 issue. It only will engage into 4x4 once in a while. No I was reading that this trucks have issues with water getting into the electrical connectors. Can anyone confirm that? Also were can I find a wiring diagram for this 4x4 part of the truck so I can identify what im looking at? Thanks! Tomi |
bounce this back up.
corrosion in connections happens... that is easy to check first
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Ok, I finally got back on that truck. Right now the 4x4 works. It shifts from 2wd to 4x4 no problem but it makes a pretty good "KLONG" when it shifts. Is that normal or does that indicate a bend shift fork or any other mechanical issue? All my trucks are old and you have to pull the big *** lever to put them into 4x4 so Im missing some experience here!
Thanks for your help! Tomi |
push-button 4x4
I can't speak from direct experience but my buddy has gone through 3 tranfers because of the push button 4x4. Once the connector got wet it wouldn't shift back into 2wd. That may not be the exact problem you're having but it's just food for thought.
| alternator acting up? or what? | KoTT | Engine | 21 | 08-11-2009 05:26 PM |
| C6 acting up. | LOWbutnotSLOW | Transmission - Rearend | 8 | 07-14-2009 07:07 PM |
| Just a too old kid acting way too young! | KevinM | Introduce Yourself | 3 | 06-24-2008 11:16 PM |
| 350 acting up :( PLEASE HELP! | purple1967camaro | Engine | 3 | 06-19-2004 07:41 PM |
| TH-350 trans acting up | Old School Nut | Transmission - Rearend | 14 | 12-10-2003 04:43 PM |
