2006 GMC Sierra Rear End Popping Noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 06:44 PM
Hey there guys. I thought I would post this video on my issue with my rear end of my 2006 GMC Sierra Z71 1500.
The truck has a 4:10 rear end.
Thanks for all of your help and suggestions! Appreciated very much.
Click the link to view video of the noise.
http://www.youtube.com/watch?v=3bcZFbSwpTI
Old 11-20-2011, 07:41 AM
dei8fan's Avatar
Registered Brain Surgeon
They all have play in and out, its not clear how much they are moving by your video.
Old 11-20-2011, 08:07 AM
delawarebill's Avatar
i'm think'n the same as 8fan
but ck the purchase date... it just might be under warranty still....
Old 11-20-2011, 11:18 AM
S10xGN's Avatar
Gotta love a turbo!
Lugnuts tight? Brakes OK?
Russ
Old 12-14-2011, 10:31 AM
My truck is doing the same thing have you figured out what it is yet
Old 12-14-2011, 11:46 AM
Wiki Edits: 31
shouldn't be doing that. they all have a little play, but not that much.
your trucks telling you it's time for a 14 bolt swap
Old 12-14-2011, 11:49 AM
OK I figured it had too much play on it but how do you fix it
Old 12-14-2011, 12:16 PM
Wiki Edits: 31
hard to tell. almost sounds like the c clips arn't holding it in as they should.if the bearings are shot, it could possibly do that also, but they would have to be worse than bad. to the point there doing damage
Old 12-14-2011, 12:25 PM
OK well I'm bringing by the shoo to look at it today to see what the fix is gonna be ill post what it is once I've found out
Old 12-15-2011, 08:25 AM
Does it make any bad noises while driving?
If not, its wear in the diff, particularly if its a GovLok.
If it makes other noises, its probably the diff carrier bearings.
Old 12-15-2011, 08:35 AM
OK truck is fixed the 4:10 rear ends on these trucks ate Mae to have a good bit of slack in them. The noise I would hear at takeoff from a dead stop was actually the slip yoke being dry the dealership put some grease called "smurf snot" and its fixed
popping noise MosinNagant Engine 2 05-10-2010 05:11 PM
'98 cherokee frnt differention popping noise newdad1 Transmission - Rearend 29 08-04-2009 10:48 AM
popping noise capn_crunch4x4 Transmission - Rearend 1 05-19-2006 01:30 PM
popping noise... 97Z28 Suspension - Brakes - Steering 8 02-20-2006 05:05 PM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 09:17 PM
