Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 2006 Silverado dash lights out how to replace them?
Old 03-28-2012, 10:16 PM
Dave57210 Dave57210 is online now
Semper Gumby
Wiki Edits: 2
Originally Posted by latech
They are soldered to the printed cicuit board. There not real hard to replace.
Be sure to wear a static ground strap while handling the board and when soldering/unsoldering.Perform all soldering/repair on the static matt that you will need to use.Radio shack has them for 25 bucks.
Bulbs can be bought from a few E Bay guys, just look around.
I have also replaced the stepper motors for the gauges.Its all soldering work....so. bone up on the soldering skills.
There are places that repair them just pull it and send them in.
The hardest part about replacing the stepper motors is if you dont have a scanner(like mine) to activate the gauge to say for instance... half scale so you can properly calibrate/install the indicator needle.Replacing the bulbs requires soldering only.
The HVAC head has the same bulbs also.They too need to be soldered.
Be careful trying to get the HVAC control apart, you have to pull the knobs off to split it open, sometimes a few guts come out when you do...
The sliders will be the most trouble.
Luckily (if that's "Lucky") there are no sliders. Mine has the two rotary knobs (one for passenger, one for driver) so each can set their own temperature. Push buttons for turn on/off the A/C, defrost, rear defog (and mirror heaters with same button) turn on "auto climate control", adjust fan speed, etc etc
About half of THOSE are out too, as are the ones behind the buttons for the 2wd, 4wd, 4wd-low range etc. All of the ones on the steering wheel are out, most of the ones on the stereo are out as well.
I'm thinking that a buddy builds computers and also builds Ham radios and other electronic stuff, so I'll ask him to do the soldering for me. I think I'll go for LEDs behind all the buttons, (so they last "forever"!) but I'll stay with bulbs (so I can dim them) in the gauges, but LEDs for all the indicator lights (parking brake, seat belt, airbags, glow plugs, yada, yada. yada - I think there is about a "zillion" of those, too!)
