2006 Silverado Tail-lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2008, 09:58 PM
Ok, so I noticed that the 07-08 trucks have two red tail-lights, separated by the rev. light. These red lights both activate with parking,turn,brake. Now, my truck also has two red lights,(on each side of course) both dual-filament,but one is only turn signal . I'm so sure this is problem involving a little tapping or jumping, and I have "expanded-basic" experience with this, (I install LED's on all my vehicles, plus cb-radios,etc.) Basically, I want both lights on both sides to use all three functions. Thanks, Vic
Old 05-01-2008, 08:41 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The side that you have turn only is a problem with the newer Chevy trucks. They have a circuit board built into the light that goes bad. The turn and brake light use the same filament in the bulb, and the other filament is the running light. The dealers have them in stock.
Old 05-01-2008, 11:18 PM
I'm not sure we're on the same wave-length here. Not to offend but I was looking for a way to rewire my '06 Silverado tail-lites to blink etc. just like the '07-'08 lights do,both together(on each side.)Help? Vicman
Old 05-01-2008, 11:24 PM
My 2 cents worth
Wiki Edits: 3
Now I understand after reading your edit and responding. I check to see if it is possible.
Old 05-01-2008, 11:45 PM
33mopower's Avatar
33 Mopar addict
Last journal entry: 1933 Dodge commercial sedan
You go to wall mart and buy a trailer wiring converter. Its shuts off the brake light when the turn signal is on. I also do led retrofits and have used this product many times. Like 13 bucks. If you have a circuit board mounted to the taillights you may have to get creative and add a jumper or two.
Old 05-03-2008, 09:26 PM
Thanks guys, I may just "dink" around with them(after I get some fuses and bulbs---for the inevitable blow out or two) and if successful, I'll post it for all to see.. Thanks again
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 01:06 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
tail lights screwed. need help 406 ss monte Electrical 6 12-26-2004 08:04 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
EZ wiring harness, tail lights 53chev Electrical 4 11-05-2002 06:23 PM
