2006 silverado trans problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2011, 11:14 AM
2006 silverado 5.3 i believe 4l60 trans. 4wd short bed reg cab. 28000 mi.
no check engine light. trans seems like it's slipping in and out of O.D. between 45 and 55 mph.
anyone got any ideas before i give my left arm to a shop?
Old 10-03-2011, 01:53 PM
it could verry well be lockup, rpms are not fluctuating that much- 100ish rpm at best but i can definetly feel it in the seat of my pants. and i do have an autotap scanner that i'm pretty sure has shift data.
what is tcc?
thanks 65 blue ss
Old 10-03-2011, 02:56 PM
- TCC-Torque-Converter-Clutch-Connection-Valve
gutcha
Old 10-07-2011, 01:17 PM
hi Frank, first of all thank you for your input...
here's what i got with my scanner:
TCC PWM Duty Cycle - stays in the range of 95% to 96.9%. but within the 45 - 55 mph range TCC PWM fluctuates betwween 10 and 40% farly rapidly, say 1 to 2 times every 5-10 seconds. this data does not change weather there's a load on the drive train, up hill, down hill or on level grade.
TCC Apply Time - Stays around 0.25 seconds.
TCC Slip speed - 20 to 30 RPM within repective mph otherwise low #s 1-5.
Trans temp sensor - 3.0's Volts. reads Volts?. Gear change data did not change.
i got a bunch of other data, this is the TCC stuff.
sounds to me like a data issue? if i'me getting readings does this mean the comp. is telling converter to lock unlock?
I seem to remember swapping out the vac modulator on my 65 Chevy and moving on... dam.
06 i've herd everything from a bad diod in the altenator to a complete Enigine Controll Modue will cause this.
Awaitin input.
Thanks, Steve
Old 10-07-2011, 05:38 PM
TCC solenoid fused?
is TCC solenoid fused? if so what will happen if i pull the fuse? (diag test)
2006 interior in a 90's silverado bigdog7373 Interior 8 12-30-2010 06:16 PM
firing order 2006 chevy silverado 5.3 v8 2wd pacifico1972 Engine 5 10-30-2010 06:36 PM
94 silverado z71 trans problem spartan117 Transmission - Rearend 4 05-10-2009 06:53 PM
2006 Silverado Tail-lights Vicman Electrical 5 05-03-2008 09:26 PM
Chevy Silverado Trans cable aminga Transmission - Rearend 1 04-02-2006 07:36 PM
