2007 mkz - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 11:47 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
2007 mkz
Do any of you ford guys know how you check and add oil to the front diff. on a 2007 linc. mkz all wheel drive. Seems to have a leak between the two halfs but couldn't see any way to check it.
Old 06-02-2013, 02:56 PM
swvalcon's Avatar
Someone must know how to put oil in one of these things
Old 06-02-2013, 03:53 PM
techinspector1's Avatar
Wiki Edits: 326
I first ran into this crazyness a few years ago when I sold Toyotas. The new models came out with a sealed trans, no dipstick.
It's a good idea to have a factory service manual on hand in the event you want to do your own maintenance or repairs.....
http://www.faxonautoliterature.com/Search.aspx?c=166294
Old 06-02-2013, 05:12 PM
vinniekq2's Avatar
sealed units and special oil.
Old 06-02-2013, 08:42 PM
LATECH's Avatar
I ran into that a while back. Fill it through the drain hole by making a rubber plug for a squeeze bottle . Naturally all the fluid will run out when you pull the plug. Drain it. Check it for metal.
Use GL-5 rated gear oil.It may take 3 pints so you will need to change the bottle once.
Jam the plug into the drain, fill , and be quick to plug the hole when removing the filler plug. Its the only way I know.
Fact is stranger than Fiction
Old 06-03-2013, 06:23 PM
swvalcon's Avatar
I checked with ford today and it comes factory oiled and isn't suppose to need to be changed or added to. But they said in case of a small leak theres a plug on the side if you can get to it. Then you bend a wire tie at a 90* at 1 3/4"s long, stick it though the hole and it should show a 1/4" of oil on it. Leave it to Ford. THese new cars are something else. I hate to tell the dummies anything with oil in it will leak sooner or later.
mkz swvalcon Engine 0 05-20-2013 03:00 AM
2007 mkz swvalcon Suspension - Brakes - Steering 2 05-04-2011 05:49 PM
2007 Rod & Custom Americruise 2007 pictures posted wp442 Hotrodders' Lounge 2 07-04-2007 01:59 AM
2007 charley1 Off-Topic 0 01-01-2007 11:46 AM
2007 already 12.36 am. leo27 Off-Topic 2 12-31-2006 08:19 AM
